8th digit on VIN is a "J", whats that?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Jun 4, 2003.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    8th digit on VIN is a \"J\", whats that?
    i tried to decode the VIN on this chevy cab i have, and it shows the letter "J" in the "engine type and make" section. as shown in my Chiltons manual, this "J" should be for an "El Camino Only" which is a 4.4L v-8 2 barrel found only in an el camino. can anyone help? thanks.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: 8th digit on VIN is a \"J\", whats that?
    "J" is usually the code for a diesel engine when it comes to light duty trucks. What year is your truck? If it's early 80s then chances are your truck was originally equipped with a 6.2.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    "J" code = 6.2L diesel (non-EGR) /forums/images/graemlins/wink.gif
  4. Can Can
    15,552
    136
    Actually, depending on the year of the truck, "J" doesn't always mean diesel. I believe in the mid to late 90s "J" was the code for a 454 and GM started using "F" for the 6.5.
    Just a little FYI. /forums/images/graemlins/cool.gif
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Yeah, on my 98 Sub the "J" means 454 if it was a 350 it would be "R" I believe.
  6. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    thanks guys. that was quick. this site never ceases to amaze me. the truck is an 82 3/4 ton. thanks again. i wonder why the Chilton's couldnt tell me that.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Because it's a Chilton's manual! /forums/images/graemlins/wink.gif The factory service manual set has about 5 times as many pages as a Chiltons or Haynes, plus the factory manual set is specific to a single year, while the other two typically try to cram in data from a wide range of years. So guess which one has the most info available? /forums/images/graemlins/shocked.gif
  8. Grim-Reaper
    7,385
    Atlanta
    That digit in 88 a N is 454.
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    In 82 the J is a 6.2...
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    My RPO code book lists the "J" for an '88 to have the 6.2L diesel.
