9.5 sf axel ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bablazer73, Jan 12, 2003.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have a 9.5 semi floater from a 85 3/4 ton I want to put in my plow blazer. Another member has a posi unit from an 88 3/4 ton truck(newer style) I know that the 8.5 axels changed axel splines around that time. does anybody know if the 9.5's did the same? will his posi unit fit my axel?
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If im correct the 9.5" rear axles all have 33 spline axles.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    Yes, they are all 33-spline. I put 6-lug shafts from an 88+ into a mid-80's 8-lug version. No problems. The only things that have changed about these over the years that I am aware of is on the ends. There have been different brake sizes, which affects the length of the axle shaft and different lug configurations, which affects the flange, but everything on the diffential is the same.
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    great. i am only gonna use the posi. i kinda like 8 lug blazers. look tougher!
  5. Blue85
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    [/ QUOTE ] Usually are tougher!
    Just remember to do a full ring and pinion setup if you swap the carriers. You probably know that already, but just checking.
