9.5 sf in blazer e-brake cables?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bablazer73, Nov 10, 2002.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I am thinking of swapping axels in my 87 plow blazer. I have a set of 3/4 ton axels with 3.73 gears. The rears is a semi floater. I need to keep e-brake working. stick truck. What ebrake cables work with the sf axels into blazer??
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I believe you should be able to use your old e-brake cable on the new 14 bolt SF. I put that same axle in my sub. and the cables switched right over. What year is the 14 bolt axle you have? /forums/images/graemlins/burb.gif
  3. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    The axels I have are '85 pick-up axels.
