9.75" or 12'' rims
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Mar 30, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    9.75\" or 12\'\' rims
    When I get the wheels for my Blazer what do you guys recommend for the width for a 38X15.50X16.5 tire? 9.75x16.5 or 12x16.5?
  2. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Re: 9.75\" or 12\'\' rims
    I would say you have to go with the 12x16.5 otherwise those meats will ballon out over those 9.75" rims.. you dont want that, plus you would pop the beads on them easier.. good Luck.
    BlazerBoy
    http://generalblueballs.coloradok5.com
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'd go with the 9.75".... Less rim sticking out to grab rocks and stuff!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    replies to this are going to vary both rims will work and as far as what one to go with will vary on personal preferances(sp?)
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    What kind of wheeling do you do? Mudding is fine with 16.5 inch rims, since you don't need to air down. Rock crawling and 16.5's don't mix well. There is no safety bead on 16.5 inch rims so at low pressures it's very easy to push the bead off the rim. [​IMG]
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, if your gonna be crawlin' you probably want the narrow wheels so there is a little less chance of loosing the bead. Probably better to avoid 16.5 in the rocks though, just my opinion...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My personal preference would be the 9.75" rims. These are plenty wide enough for a 15" wide tire, plus they will be better protected from rocks and roots if you do go fourwheeling. The narrower rim will also hold the bead better than the 12" rims.
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I second Harry's responce.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  9. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Not that much wheelin' so far, just some mud when it rains and screwing around in the riverbed. Dont really go that often. Would like to go on some trails sometime, but I am new at all of this.
  10. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    I would go with some 16X10 wheels,
    Of course this does limit the tires that are available
    But you would be able to blead down the pressure, and that is a must in rock's and sand!
    Scooby Dooby Doo !!!
  11. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I'd go with 9.75's and a yes with what HarryH3 said.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
