9.75 rims on 14.50 tire??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Jun 17, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    im lookin to get new rims im planing on gettin black rock crawlers and i was wondering if i can run a 16.5/9.75 inch rims on 38.5/14.50 tires weill those rims be able to work or are they to skinny?
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Close call there. Get 10" rims if you can.
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    No one makes a 10" rim for the 16.5" size. Its just a 9.75".
    I have run 39" Mickeys with 9.75" rims. Those Mickeys were like 15" wide. I have pics of this truck posted somewhere in this forum. It worked good too.
    BTW, a 9.75 rim for your 14.5 wide tires would work better than a 12" wide rim. The narrower rim will keep the beads seated better at lower pressure than a 12". 16.5's have no safety beads, so a wider rim will pop off easier than a narrower rim when aired down.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Years ago, when I managed a Goodyear store, we were told that you should keep the tires to within 4" of rim width...all fractions aside, you are close enough for it not to matter....I just wouldn't run anything wider....it'll fit, but uneven wear becomes an issue....true, 16.5's are not a safety bead, so lower pressures will unseat themselves....you may consider switching to a 16" aftermarket rim/tire combo for more flexibility in the way you could use your tires when wheelin'.....just an opinion....JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....Stuck?...Hell no..I still got some gas left..
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I ran 10 inch wide tires with 14.50 tires before and it was fine. 9.75 is so close to 10, that I'm sure that will be fine too.
    '73 K5
    Chevy good...Ford bad
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Do you already have the tires?
    If you don't, go for the 16" setup.
    Dave
    Don't Be Sexist - Broads Hate That
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I'm sure that'll work considering I ran 16.50 inch wide tires on 10 inch rims... never broke the bead never had a problem... loved the fact the tire stuck out and protected the edge of the rim to from getting thrashed...!
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I've got a set of 35x12.5's mounted on some 6.75" factory steel rims. Near 40,000 miles on em without any weird wear patterns...
    Rene
  9. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    no i dont have the tires yet i just watned to make sure they will fit before i buy them you know ?,ok thanks alot for all the advice guys and gals i think u help me out alot i might go for 16 inch rims but if i go 16 inch rims wont i have to grind the brake drums a little ?or something or other ?
  10. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    The 9.75" rims will be fine. I run 9.75" wheels with 14.5" Swampers and they're fine plus the wheel is protected from rocks a little more. Good luck finding a 38.5" tire that mounts on a 16" rim. The only maker I know of is M/T and Parnelli Jones. Interco might make some at the end of this year. You won't have to grind with 16" wheels though.
    Shawn
    87 K5
    few mods [​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Does it look stupid to have that much tire buldge from a skinny rim/wide tire? Haven't seen it.
    -- Mike
  12. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The recommended rim size for my 15-39.5/15s is a 15 x 10.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
