$9.99 for driver and passenger 4point harnesses!!!!
Discussion in 'The Garage' started by jjlaughner, Nov 9, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK now that I have you in here /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
    Those who have them how did you mount your harnesses in your cage setup? What seats are you using? Needs to have a wide seat, no sidebars or high edges /forums/images/graemlins/tongue.gif
    I won these on ebay (yes $9.99+shipping and stuff (still $34 shipped for a set of two)
    Thought about doing a cross bar at the doors, with two bars going from the driver side to passengers side like this (ignore the back two bars)
    and mounting the seats and console inside the cage on the crossbars...
    Think it would be good enough?
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Re: question about mounting 4pt harness, seats in cage
    Curiousity... What is "CHEAP"? Looks like the right idea... I plan on going that route with mine once I get the cage in! /forums/images/graemlins/thumb.gif
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    With belts like that you want the mounts for the shoulder belts on either side of your neck straight down your back as possible. For the lap belts, in the normal mount points. Hope this helps. Good luck you y'all.
    Allan
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Cheap would be..... $9.99 closing bid /forums/images/graemlins/thumb.gif
    OH THATS A PAIR by the way, driver and passenger hanessES (plural)
    If people didn't see this post about cages, its worth the read
  5. Batmanjr
    Mar 23, 2001
    1,537
    Sweet! Nice score! /forums/images/graemlins/thumb.gif
  6. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Good price, but the $18 shipping and handling is kinda steep. /forums/images/graemlins/frown.gif
    -Andrew /forums/images/graemlins/usaflag.gif
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    btt, anyone /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This shows fairly clearly how mine are mounted.
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Cool deal /forums/images/graemlins/thumb.gif
    I think mines going to be a little different, my harnesses have the bolt on type ends.
    how do you like this
    [​IMG] ?
    /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, looks familiar... /forums/images/graemlins/thumb.gif
    [Edit] BTW, mine have the clip on ends but that's not going to really change the mounts. The shoulder straps on the Corbeau straps is very long so the grab handle thing was added as a support to redirect the strap to a loop mounted on the lower cage section (and take up some length). The loops I used were mostly chain links with one end of the loop cut off and the points beveled for a very solid small fillet weld. The side mounts needed to be taller to clear the floor so they were made with a split link normally used for splicing chains. Added bene of the split link is it gave me 2 horizontal sections to weld and horizontal stability in all directions.
