'90 350 TBI Engine Question
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Sep 27, 2005.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What type of bolts were typically used for the EGR valve?????????????
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Im not positive, been a while since mine was off, but a 12pt 9/16" cap rings a bell.
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    If it is stock the manifold should have studs with a 13mm or 1/2 nut holding the valve on.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah I'm pretty sure mine was 13mm or 1/2 nuts on studs.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Same here. Two studs that screw in using a "reverse Torx" socket. The tip of the stud is shaped like a Torx driver and takes a socket that fits over it. They don't have to go in super tight. Just snug 'em down and then slide the EGR valve over the studs and install the nuts.
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I have one stud and one nut....guess I'm a freak. :crazy:
