'90 454 from 3/4 Ton Suburban
Discussion in 'The Garage' started by sjvcon, Nov 2, 2004.
  1. sjvcon
    sjvcon Registered Member
    Feb 10, 2004
    52
    Queen Creek, AZ
    \'90 454 from 3/4 Ton Suburban
    Does anyone know if the 454 from a '90 3/4 ton Sub is a 2 or 4 Bolt? I am looking at buying one to swap into my '79 K-20 Sub, and was just curious...
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
  3. sjvcon
    Feb 10, 2004
    52
    Queen Creek, AZ
    Re: \'90 454 from 3/4 Ton Suburban
    Problem is that it is in a vehicle about 100 miles from me ... running vehicle. The price is right, but just was curious. Even if it is a two bolt, it wouldn't be bad with ARP studs, but I'd rather have a 4-bolt. I thought someone may know based on the year and model what was put in ... anyone /forums/images/graemlins/confused.gif
  4. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    If it was cheap enough I'd buy it regardless--even if you find its a 2 bolt main and dont want it,chances are you could re-sell it at a profit to someone who doesnt care.Big Blocks are like money in the bank around here--I know of one guy who sold a bone stock 396 from a rotted chevelle he got for 100 bucks through his scrap car removal business--he spent about 1 hour making it start and run,and by the end of the day he was fighting off 2 people who wanted to buy it for 500 bucks!. /forums/images/graemlins/eek.gif /forums/images/graemlins/crazy.gif
  5. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    The 350 that we pulled out my 90 3/4 burb ended up being a 4 bolt main. I don't know about the 454's they put in them.
    The 454 I had swapped in is a 2 bolt main & haven't had any major problems yet /forums/images/graemlins/peace.gif
  6. rcamacho
    Jul 1, 2004
    1,324
    WA
    2 bolt mains are fine unless you plan on revving over 6K. If so, you probably have the budget for a 4 bolt block or installing aftermarket billet steel 4 bolt caps. A 2 bolt block usually has enough material in the mains for installing aftermarket 4 bolt caps. Line hone will be required though.
  7. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    The 454's from 88-90 which is the old mark VI big block were all changed to 4 bolt mains in those years. All the big blocks from 1988-2000 come from the factory with 4 bolt mains.
    bigred81
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I'd bet against you there, my 89 C3500 has a 454 MK-IV, 2 bolt (original engine).
    All gen 5 (91-95) and gen 6 (96 up) have 4 bolt mains.
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    1990 was the last year (I think, or was is 1991?) for the MKIV engine. I could be either a 2- or 4-bolt main. I know for sure 1992 came with a GenV motor that lasted until ~1995 and then they came with the Gen VI. Both GenV and Gen VI BBC's are 4-bolt mains. I have a GenV that is from a 1992 K3500. The best thing to do is find the casting number on the heads and on the block and see what creature you have. You probably have peanut-port heads and a 2-bolt main; thats my guess. GM was fond of using the peanut port heads on BBC's in truck applications.
    Either way, if the price is rigt, get it. You won't ahve any problems with a 2-bolt main unless you are wrapping it to 6000+ rpm constantly and making 500+ HP. And you could always have 4-bolt splayed mains added if you did want a ridiculous motor. the aftermarket splyed mains would be stronger than the factory 4-bolt stuff anyhow. There is a machine shop here in town that is doing 4-olt splayed mains on a SBC I am building as we speak for $350 including billet bearing caps and I don't think it could be much for for BBC stuff..
    Chris
  10. sjvcon
    Feb 10, 2004
    52
    Queen Creek, AZ
    Well, I would be getting a whole running donor 'burb (2wd) for about $1500, which is not too bad out here. I need all the smog garbage due to state laws. Otherwise I would just buy a motor from Chevy. It will need a rebuild, so doing the splayed caps wouldn't be too hard I guess.
