90 Blazer "U" joint replacement ?
Discussion in 'The Garage' started by opfor2, Sep 23, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    My main driveshaft front u joint is starting to click so I would like to replace both of them. I looked at them and they don’t have any visible retaining clips. There seems to be a white plastic stick pushed in to hold them on. Is this correct or am I missing something?
    Also, what are the best and strongest joints for this truck?
    Dan..
  2. gmcjimmy90
    gmcjimmy90 Registered Member
    Jul 3, 2005
    76
    arkansas
    yes they are held in by plastic so you have to heat it up till all the plastic comes out. but be careful because it will pop and could burn. as far as the u joints go i run cheap ones, would rather break ujoint then driveshaft.
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    OK, that's about a bunch of Sh*t!! Do the new u joinnts come with the plastic rod? or can it be modified to use the clips?
    Dan..
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    just go get yourself some spicers
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    New joints will come with clips.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    the stock chevy ones have those stupid plastic inserts u gotta heat them up till they pop out. the new ones u get from napa just have the clips. :)
  7. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    So I’m assuming that the new u joints with clips will work on my 90 Blazer? I was planning on going to NAPA to get them.
    Dan..
  8. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    yes sir
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    what the P/N for the hi amp alt you have? is it a large case?
    yes the new joint will work with your d-shaft
  10. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
  11. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    The factory joints come with a plastic retainer that has to be melted to get it out.. You will need a Oxy-Acetylene Torch to get them hot enough because a small bottle torch even with map gas dosen't get hot enough to melt them.. The new joints will come with regular clips to put them back together..
    As for what joint is the strongest or the best that would be depending on how much you want to spend and who you ask :D Napa has a couple different grades and I'm sure they will point you in the right direction..
  12. gmcjimmy90
    Jul 3, 2005
    76
    arkansas
    i have used a little bottle torch many times and it worked fine
  13. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I would just take them to a machine shop and pay $20 to have your u joints pressed out and new ones in. Worth the trouble for me, at least for the CV's.
