90 Blazer with a door alignment problem??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Jan 1, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi all,
    Over the past year or so It’s been becoming more and more difficult to close the drivers door without slamming it two to three time before it will properly close. I’ve also noticed that the top of the “door striker bolt” has some wear marks on it. I’m wondering if the door striker bolt has come out of alignment and needs to be adjusted. I attempted to remove the drivers bold but all I ended up doing was stripping the hex bolt. I’m just thinking about replacing both bolts with new ones and I was wondering on how to properly remove them.
    Thanks in advance
    Dan..
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    check the hinge bushings, most likely they are warn and need to be replaces, that should fix the alignment problem
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    i'D BE WILLING TO BET THAT THE HINGE PIN BUSHINGS ARE WORN OUT .
    GET NEW ONES @ THE DEALER OR YOUR FAVORTE PARTS HELP SHELF.
    OPEN DOOR ALL THE WAY.
    USE SUPPORTS TO SUPPORT END OF DOOR.
    POP HINGE PIN OUT USING HAMMER AND PUNCHES AND PRY STICK.
    USE HAMMER TO REMOVE OLD BUSHINGS.
    REPLACE OLD BUSHINGS, USING HAMMER TO SEAT FULLY.
    ONLY REMOVE ONE HINGE PIN AT A TIME, SAVES REALIGNMENT TIME!
    REINSTALL HINGE PIN.
    READJUST STRIKER BOLT IF NECESSARY.:D
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    One last thing. There is supposed to be a nylon roller on the striker bolt. With the nylon roller there even a door with crap hinges will latch reasonably good. Prolly a GM dealer part..but well worth replacing.
    Rene
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It is probably the hinge pin bushing, you can buy new pins and bushings for like $20.
    BUT WHATEVER YOU DO, follow the other guys advice of doing it on the truck, don't go and loosen and remove the hinge mounting bolts, those doors are a PAIN to align correctly, and if you loosen the hinge bolts, your in for a day job getting them back in correct alignment.
  6. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    THANK'S !!!!
    Do you think NAPA will have the Hinge Pin Bushings ?
    Dan..
  7. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I bought mine at NAPA. Look in the rack with all the "help" stuff
