90 blazer with th400???
Discussion in 'The Garage' started by COCHEV, Mar 12, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    was this a factory option? found the fallowing in the portland autotrader:
    90 blazer
  2. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    The only choices were the 700r4 or the sm465, I believe. Unless it came in some sort of package with the bruxh guards. /forums/images/graemlins/grin.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Turbo 400's weren't ever offered in K5's. /forums/images/graemlins/frown.gif But it's pretty easy to swap one in! /forums/images/graemlins/thumb.gif
  4. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Interesting. I've messed with a LOT of K5's in the last 20 years and have never seen one with a stock Turbo 400. Does anyone out there have a K5 that came stock with the 400 cubic inch engine? Did that option trigger the installation of a Turbo 400? Or is the spec sheet being optimistic? /forums/images/graemlins/shocked.gif
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    My 78 GMC Jimmy came with the 400ci motor, but with a Turbo 350 tranny, wish it had the 400 trans in it!
  7. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    didn't they make a 454 blazer with a th400?
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I dont know if you classify the M1009 as a blazer, but it came with the 6.2 T-400/208 combo. /forums/images/graemlins/laugh.gif
    John
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    no big-block K5's /forums/images/graemlins/frown.gif
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    No Blazer or Jimmy was ever offered with a big block. There was a guy on here who had a Blazer with what appeared to be a stock TH400 a while back. I think it might have been a Chalet.
  11. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    There is one 79 Blazer here with 350cid th400 np205 from the factory. I do not know what other options it has.
  12. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well just to clear things up a little.
    I had the 76-77 broshures, and if you look at the broshures link somewhere here on the site, you will find the same:
    There was an option for a 400ci small block, but it could only be had with the th400.
    I don't remember what Tcase was offered with it but you can look it up.
    The th400 was otherwise an option that not many chose but still was available behind the 350ci.
    Now the M1009 I believe is the equivalent of the civilian blazer and it never came with a th400 or D60 or 14b, like some people claim, only 10b/10b/6.2/700/208.
    The M1008 which is the 1 ton pickup military issue did come with th400/208/D60/14bFF.
    So stock blazer th400 was an option but only up until 80.
    Big blocks were never offered in Blazer but many people opted to put one in, and some dealers put big blocks and named them SS blazers.
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I still believe that the M1009's came with 400's. I am pretty sure of this, but could be wrong /forums/images/graemlins/confused.gif
    I know I saw an M1009 with a 400 in it. I was fairly curious, b/c GM never offered it to the civilian market in a Blazer.
    My .02,
    John
  14. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    was that only for 76-77? cause my 79 blazer had factory sb400 with a th350/203. was all on the build sheet too.
  15. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    All CUCV M1008 5/4 ton pickups /forums/images/graemlins/truck.gif and M1009 Military Blazers /forums/images/graemlins/k5.gif came with TH400 tranny's. The Blazers all had 208 cases and there was a option of getting a 205 on the 5/4 tons if it was a ambulance or a radio carrier pickup. The standard M1008 pickups had a 208 case also.
