90 IFS 4x4 STOCK suburban...width of front end? HELP!!
Discussion in 'The Garage' started by uglychevyZZ4, Aug 23, 2006.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I need the width from outer sidewall to outer sidewall on a 90 IFS 4x4 Burban.. i am supposed ot drive 150 miles tomorrow to pick one up and am trying to figure out if a tow dolley is wide enough.. HELP!!
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    First off, suburbans weren't IFS until 1992.
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok well 92/3/4.. either way, its early ifs.. satisfied :D
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Now i am. :D
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just measured my '94 for ya. It's at 78 inches, sidewall-to-sidewall. Mine has aftermarket wheels that have an additional inch of offset on each side, so figure 76 inches with stock wheels and even a bit less with the stock size tires. (Mine has 285/75R16's that are a tad wider than stock. )
  6. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    Tow dolly isn't gonna be wide enough, but it's not enough to worry about. Just tighten the straps tight as you can, and check them now and then.
