90 Jimmy Xformation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Mar 22, 2001.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    O.K. everyone...my first post. I've finally gotten the vehicle I've been looking for over about 4 years of searching and settling for less with a few later model tahoes. I've got a real one now...a 90 Jimmy with 3:42 gears and I'm getting ready to put my 4" skyjacker lift on with 35x12.50's. This is going to be my everyday ride so some practical advice would be appreciated. I'm planning on going with an ORD steering box support and stabilizer disconnect. What about the gears? Some people have suggested 4:11-4:56 but if I don't care that I'm sluggish does it matter? What about headers for a 90? What are some good applications to replace stock exhaust manifolds? I also need a new headliner and also want to replace the seats for something more comfortible. Let me hear from you. lehto@capital.org
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Yes, it does matter. With 35's, I think 3.73's are the bare minimum you could get away with. 4.11's or lower would be far better; less stress on the engine & trans. Speaking of trans, have the trans powerflushed, then get a big transmission cooler. Change ALL the fluids so YOU know they're good. As far as headers go, the Flow Tech Afterburners seem to be a good, inexpensive choice that make good power. If you've got more to spend, the Doug Thorley Tri-Y headers are, in my opinion, the best choice. Thick flanges, heavy-gauge tubing, Tri-Y design for max torque. Aside from cost, I've never heard a bad word said about these headers.
    [​IMG] Semper Maintenance!
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I would highly recommend investing in the gear swap to at least 4.11 gears. This will help both off-the-line power and also fuel economy as compared to the stock 3.42 gears. I know gear swaps can be pricey, can I think you get just as much, if not more, of a performance gain by having the proper gears for the tire size then if you spent the same on engine parts. Also, the transmission will be much happier with the gears also.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I used to run 3.08's with 35's and now i run 4.10's with 35's. The 3.08's weren't that bad, but the 4.10's are better. The 3.08's were liveable.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  5. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Deff. change all fluids. Dont forget the xcase and front and rear diffs, the same technique for the tranny can be applied to chage the diffs..
    Seats-- Ill buy your old ones
    Headers-- dont buy cheap ones. Deff. get the thickest flange you can find. Borla is good, so are the above mentioned. Deff!!! dont get cheap dyno-crap (dynomax) like i did, they leak and always need to be tightned.
    Wheels... what are you doing with the stock ones?? Love to buy those also
    Ben
    www.BenjaminBone.coloradoK5.com
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The headliner should be pretty easy to do yourself...all the places say to get it done profrssionally but its BS. i helped a buddy make a new one for an S-10 Blazer which has a helluva lot bigger headliner than a K5 and it was really easy. We did it for about $20, 12 for the board at a junkyard, 6 for the glue and 2 for the fabric at a discout fabric place. It looks OK, the color doesn't really match, but for $20 it looks awesome. If you got real headliner material it would look better.
    90K5
