90 or 91 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ed Mancini, Jul 17, 2000.
  1. Ed Mancini
    Ed Mancini Newbie
    Jul 17, 2000
    Hi-
    I am in the market for a 90 or 91 K5 Silverado and I was wondering if there are any specific engine, chassis or body problems that I should look out for.
    Also, since I live in the Northeast, I would like feedback as to how the body on the 90 or 91 has faired in salty & snowy conditions. I've heard that the 1991 model went to a double galvinized body to help alleviate some of the rust issues.
    Thanks.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Make sure you check for rust but it sounds like you are already doing that, and make sure the frame isn't cracked at the steering box. Those are some of the main problems on K5s
    90K5
  3. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    Check the rockers, rear floorboards, front floorboards, tailgate, tailpan(bar that runs width of truck that gate hinges are attached to), the "box" shaped thing that you can see when looking in the rear fenders toward the front of the truck(actually part of floorboards), inner fenders.....but you are from the rust belt you should know all this already. Bring a magnet with you(a.k.a.bondo-meter) I thought my 89 was still in the fixable catagory...hahaha said old man winter. what part of "northeast" are you from?
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  4. PattBlue
    PattBlue Registered Member
    May 3, 2000
    82
    N.W. Pennsylvania
    According to the Technical section of this site...which lists all the specs of Blazer..GM started Double Sided- Double Galvanized Ext sheet metal in 90..Hope this helps. I live in Erie, PA..Love that Lake Effect snow.
