90 sub "dw" like shake when braking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by basketcase, May 28, 2005.
  1. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    My 90 v1500 sub has a death wobble like shake sometimes when braking. sometimes it won't happen for weeks sometimes shakes all day all day. the truck has 4" tuff country springs in front and blocks in rear. It doesn't feel like warped rotors to me, feels alot "looser" to me. I'm kind of a newbie and could use any help looking in the right direction. :confused:
  2. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i'd check almost every bolt from the frame to the ground..
    Lug nuts, wheel bearings, steering knucles, tie-rod/drag link, steering box mounts (& nearby frame for cracks), rag joint, spring mount/shackles, etc.
    To me that 'wiggle-wiggle' when braking (or steering) is un-nerving!
  3. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    yeah, unnerving dosent come close, it scares this crap out of me. I retorqued all the lugs, they arent it. i've tried to look for cracks by the box, but i dont know what i am looking for. anyone have before and after pics? been planning to get the bolt in brace if there arent any cracks and both if there are. only reason it isnt fixed yet is i only drive it about 10 miles a week and it doesnt always do it. i also thought it could be it the wheel bearings?
  4. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    :grin: PLEASE DO THIS BEFORE DRIVING WHERE MY WIFE DRIVES!!!!!!!! :grin:
  5. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    From what I've seen alot of the frame cracks are not visable till the box is off.
    The bearings are a thought :thinking:
    We had a similar prob. with my dads truck, lift your rig and try to shake the tire (while torqued tight), this area should be quite tight. If there is play change them, it made a big differance for us.
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Do what superburb said. jack the truck up and try to physically mover the tires in and out while they are still torqued onto the truck. If they move in and out (I usually put my hands at about the 12 and 6 o clock positions on the tire and press violently back and forth looking for movement), then you need new wheel bearings. If thats not it, take the tires off and inspect the rotors. I know that warped rotors can cause a bad death wobble like feeling when braking. Chances are that your rotors are probably warped. I think they are like $20 a piece at autozone.
    -Harrison
  7. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    thanks for the help everyone. swapped the rotors pads calipers hoses and bearings today and wobble is gone!! i guess @ 163k it was time and i didn't feel like doing it more than once. all the help here makes the$25 a year here more than worth it, thanks again! :D
  8. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    also somthing you might wanna try is have some one turn the wheel while its runnin and you watch the front axle to see if the ubolts are loose causing the front axle slide on the frt springs. i did it when i first got my blazer and holy cow i cant beleive it didnt feel as bad as it looked :eek1:
  9. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    i'll check that out tomorrow
