90 Suburban 454 Problems
Discussion in 'The Garage' started by hapytmz72, Sep 19, 2004.
  1. hapytmz72
    hapytmz72 Newbie
    Sep 19, 2004
    Wondering if anyone has had similar problems. Replaced oil pump,new head gaskets....and the list goes on. The problem is that it runs for about five minutes fine , then just shuts down like its locked up. Heard of converter plug can cause this. Looking for more opinions before i yank it.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    It could be an oil pressure sending unit. The one that does NOT look like a bell is the one for the computer I believe, and if it doesnt tell the computer the engine has oil pressure it will shut the motor down.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Welcome to CK5!
    Does the engine crank over at all after it shuts off? If so, is the battery fully charged? How long do you have to wait before the engine will crank again?
    Just an FYI, the oil pressure switch the other person referred to is wired in parellel with the fuel pump relay and will allow the engine to run if the relay fails.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh but I was thinking of perhaps some, for lack of a better terms, gunk plugging it.
    Something else I thought of, does it seem like after those 5 mins it starts flooding out before it dies? Like if you work the gas can you keep it running? If so might be the IAC, or could be temp sensor in the manifold. Have you checked for codes in the computer yet?
