90 suburban trans. problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rustbucket, Oct 21, 2002.
  1. Rustbucket
    Rustbucket Registered Member
    Jul 14, 2001
    55
    northeast tennessee
    I just got a 90 suburban a while back and the thing is really nice. My wife just took it to the store and everything was fine. When she came out there was a small puddle of atf on the ground. Of course this didn't phase her at all and she drove it home. When she parked it in the driveway, it puked out every bit of fluid it had left in it. The first thing I checked was the lines to the cooler and they are all dry. The pan is soaked with atf. It's dark so I really won't be able to get a good look at it till tomorrow. Any of you ever had a similar problem and know what I should look for? It's a 90 model sub with the th700r4 trans in it. On the bright side, my friend has a 91 blazer with the same trans and he wants a 4 speed. I could get a good deal on his if need be. Thanks in advance for any help. Justin
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Just a shot in the dark... /forums/images/graemlins/smile.gif
    Sounds like the filler tube may have came loose or even out of the tranny? A large quantity of fluid egressing like that is indicative of more than just a simple pan leak.
    /forums/images/graemlins/burb.gif
  3. dyeager535
    26,980
    Now you know why he wants the manual tranny. /forums/images/graemlins/smile.gif
  4. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    First, locate where the leak is coming from. Try and replace the pan gasket, clean both surfaces very well. If its coming from the bellhousing it may be a bad pump seal. Good luck. /forums/images/graemlins/burb.gif
  5. Rustbucket
    Jul 14, 2001
    55
    northeast tennessee
