90 tbi 350 suburban stumbling taking off from idle
Discussion in 'The Garage' started by crash81, Dec 4, 2005.
  1. crash81
    crash81 1/2 ton status
    Jun 19, 2005
    289
    roxboro,nc
    anyone had this problem before? it runs great after you get just off idle but say you are sitting at light and go to take off it will stumble like it wants to cut off, you let up on the gas and it will pick up, or if you sit at light and keep foot on gas pedel just above idle speed it will take off fine. its just started the other day . any ideas ? :confused:
    Dudley :D
  2. burban J
    burban J Registered Member
    Nov 28, 2005
    8
    phoenix arizona
    wont run right
    ya mine turned out to be 2 partially fouled plugs :burb:
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Fuel pump. You will soon see that it stumbles all the time, and one day it wont start. Not too hard to change. Drop tank.
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    new plugs and wires fixed mine.
  5. crash81
    Jun 19, 2005
    289
    roxboro,nc
    got accel 300+ wires and ac plugs in it now less than 4 months old
  6. crash81
    Jun 19, 2005
    289
    roxboro,nc
    ok sounds like a good thing to change. do any of you know if there is a upgrade fuel pump for the 90 suburban to flow more fuel? that way i want have to change again when i do the tbi mods here in a few weeks. part # on the pump would be much appreciated.
    dudley :D
  7. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    Take a look at your cap and rotor too! Once that checks out OK check your fuel presure, while the gauge is on there rev the motor and look for a drop in presure. Drop would indacate fuel filter plugged or the pump going out! HTH.
  8. crash81
    Jun 19, 2005
    289
    roxboro,nc
  9. yagsinairod
    yagsinairod Banned
    Dec 6, 2005
    6
    Maryland
    tps sensor
  10. crash81
    Jun 19, 2005
    289
    roxboro,nc
    new tps already on it as well as iac
    Dudley
  11. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I am thinking your problem is fuel related. The fuel pump could be a suspect (as already mentioned). The problem could also be a fuel injector too. If you have a bad injector dribbling a bunch of raw fuel into your manifold, it will stumble at idle because it is flooding the engine, but cleans up as you accelerate because of the engines increased demand for fuel.
  12. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ive got 10 bucks on egr valve. I had that problem with mine. Every morning backing out of the drive way it would stuble and try to die then catch back up with it self rapidly and repetedly. allmost felt/ sounded like how a monster truck runs with its "surging". Asked my step dad ( life loong mechanic) what he thought and first thing he said was "egr valve" so i took and pluged the vacume line that went to it and its ran perfect ever sence. any how im not saying to do this permenently but you can try it cause it will only take a minute then if its bad get a new egr valve. blah blah blah try it
  13. crash81
    Jun 19, 2005
    289
    roxboro,nc
    what fuel pump would yall run on it? something like a walbro? like i said i'm starting a tbi buil with the high flow tbi soon so if i have to replace it i only want to do it once.
    Dudley
  14. crash81
    Jun 19, 2005
    289
    roxboro,nc
  15. crash81
    Jun 19, 2005
    289
    roxboro,nc
    well after a call to cfm they said to use a fuel pump from a 454 big block aroud 95 or 96 year truck. but he wasn't sure on it being a direct replacment to my 90 suburban. my next question is has anyone here did this and did it fit ok.
    Dudley
  16. eagle mark
    Nov 18, 2004
    3,289
    North Idaho!
    Have you checked your fuel pressure yet?
  17. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i am having the exact same problem in my 91 k5 blazer with TBI. ive been trying to figure it out for acouple of months now
  18. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Dude, bring it over and I'll help you figure it out. I have lots of spares we can swap to test stuff. Egr is the most probable cause.
  19. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Two things I'd check if the fuel system is ok.
    First -- Check your base timing. My 89 was running poorly, bogging off idle etc, when I checked the base timing, I was at like 15 degrees ATDC. Set it back to about 7 BTDC (factory is 0) and suddenly it ran like brand new!
    Second -- Check your IAC, if it is going south, it can cause bogging problems.
