'90 Tranny swap (help!)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Greg, Dec 11, 2001.
  1. Greg
    Greg Registered Member
    Jan 17, 2001
    14
    Northern Va.
    \'90 Tranny swap (help!)
    Hey guys,
    I've got a '90 k5 that I switched out a muncie 465 manual (4spd) for an auto 700R. Problem I have is the link up to the rest of the drive line. I can't use the standard Gm adaptors to connect my new 700R to the stock NP241 transfer case because the splines don't match up. ( Automatics have more spine count and smaller splines as opposed to the manuals fewer and much larger splines.) A new(er) transfer case from the junkyard is @500bucks!! Is there such thing as a rebuild kit for a NP241 Transfer case? Is it possible (or worth it) to replace the manual spline shaft in the transfer to an automatic one? Once I do this; either replace the shaft or the whole case; can the original (manual) driveshaft still be used or will the splines be different on this as well?
    Please help!
    This is turning into a bigger pain in the ass than I had anticipated. I'm already way over budget too.
    Any suggestions will be appreciated!
    Thanks.
    Greg Chezem
  2. dyeager535
    26,982
    191
    Re: \'90 Tranny swap (help!)
    Greg I can help you out with the budget thing perhaps, I need the clutch stuff off that Sm465 if you still have it. Can't help with the other stuff, I would never have even considered that swap. If I were you, and you have the SM465 still around, put it back in, and sell the 700.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Please fill out your profile...this message will repeat in...
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Are you sure it's a 241? I not saying it's not, but click here<P ID="edit"><FONT class="small">Edited by Leadfoot on 12/12/01 07:20 AM.</FONT></P>
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The 241 behind the SM465 would be 32 spline. The 700R-4 would be a 27 spline output. You would need to swap input gears in your 241 to make this swap work as well as find the correct adaptor.
    I would also keep the SM465/241 combo and sell the 700R-4 for several reasons. Strength, reliability and crawl ratio. IMHO you are removing the strongest most reliable part of your truck and replacing it with a weak, somewhat failure prone, expensive slushbox. 700R-4 and budget are not normally uttered in the same breath.
    Good luck
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
