91' 10 bolt bearings
Discussion in 'The Garage' started by Skinny D75', Jul 22, 2005.
  1. Skinny D75'
    Skinny D75' Registered Member
    Aug 9, 2000
    5
    Lake Jackson, TX
    I nuked a bearing in the right side and the new races are loose. I replaced the left ones and are good. So do the make a diferent size hub that the previous owner could have changed because they still fit the spindle. My LMC lists several bearings with same inside diameter but different outer. The old bearings and races have NO markings at all.
  2. Skinny D75'
    Aug 9, 2000
    5
    Lake Jackson, TX
    still beating my head against the burban
    I guess i answered my own question if both outer and inner races are loose. So i got another hub and hey the bearings and races fit. But now the hubs are getting hot and i have followed the instructions in the manual. hell i have backed off the nut to more than half way and it only calls for 3/8. if i go any more the hub will be to loose right? what was the use of torqueing down and seating the bearings if im gonna back it off that far ill just nuke anther bearing
