91 2.5+trans in a 96 S10 blazer possible?
Discussion in 'The Garage' started by Gooseo, Jan 13, 2006.
  1. Gooseo
    Gooseo Registered Member
    Jan 12, 2006
    7
    East Lansing, MI
    Forget the last thread by me. I went to junkyard and they said the Tech 4 2.5 will not bolt up to a trans designed for the V6 4.3. (different trannies)
    Question: Will my trusty tech 4 and manual trans slide and bolt ok into the mounts in a 1996 S10 Blazer????????????? I have the chance right now to get one super cheap with a blown motor!! I already have the tech 4 and trans I got for free.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Try the 93-older 2.5L mounts? I'm sure there's enough room to acomodate it. Might be little gutless, but 5-speed should make it somewhat forgiving.
    I forsee some frustration getting the TBI 4-banger running in an S-blazer that was etup for Vortec/SFI. :crazy: I suspect you'll need to retrofit.... then you lose OBDII. Emission testing might be a problem. :thinking:
  3. Gooseo
    Jan 12, 2006
    7
    East Lansing, MI
    I would use the ECM that goes to the 2.5, the one for the 4.3 wouldnt work. Theres no emission testing in michigan.
    So are you saying I would have to weld in the mounts from my 2.5? That the 96 S10 blazer and the 91-93 S10's dont have the same motor mounts?
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    I'm thinking the 2.5Ls mount are a bolt-in, or if not, then drill some holes and bolt-in ;)
    The 4.3L mounts did change... but not until '96. IIRC it was revised for better vibration control, not fitment. The 93-older and 94+ frames are actually quite similar even though the sheetmetal changed considerably.
  5. Gooseo
    Jan 12, 2006
    7
    East Lansing, MI
    So the 95 had the same motor mounts eh? hmmmmm
