91 A/C problem?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Jul 19, 2002.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    When I turn on the a/c, the fuse pops. I can turn on the fan on high on vent, but if the a/c pump runs, it pops the fuse. I tried it today with the fan on medium and the same thing happened. Any ideas??
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Ohm.the clutch coil....3.5 ohms is spec...
    Azblazer
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    unplug the connector at the compressor for the clutch coil, turn on the A/C compressor, if it still pops the fuse there is a short in the wire out to the clutch, if it doesn't the clutch coil is shorted out.
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I umplugged the pump and ran the air without the pump for about 30 minutes and the fuse didn't pop. It only pops when I am driving with the ac on. I will check the ohms later on today. Thanks for your help!
  5. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    OK!! The story gets better! I test the ohms and they where close to 3.5. I turned on the air in the drive way, and smoke and that great smell of burning electrical came from the control panel. /forums/images/icons/shocked.gif So this weekend I will be tearing the dash apart. /forums/images/icons/mad.gif I am guessing that was my problem from the start. /forums/images/icons/confused.gif We'll see this weekend!!
