91 Burb - with ABS - two questions about the ABS/lifting/14BFF
Discussion in 'The Garage' started by BurbinOR, Dec 5, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    This 91 I am interested in has ABS -
    1. Lifting it - do you have to move something that deals with the ABS? Seem to remember Steve Fox having some issue.
    2. What is the actuation of the ABS? If you put a 14BFF in it, any issues related to the ABS.
    Seems the ORD Tuff Country spring discount might come in handy........... /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My '90 supposedly has rear wheel ABS. But there weren't any extra connections to make when I swapped the 14 bolt into it a couple of weeks ago. /forums/images/graemlins/cool.gif Maybe they just monitor the VSS to "know" when the rear wheels have locked? I don't have a manual for a '90 yet, so I don't have any details.
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I think HarryH3 is right about the VSS. I replaced my 10 bolt with a 14 bolt FF and a disc brake setup with no issues. Oh, I also have 9" of lift.
    When I was bleeding the brakes I could definately tell the rears did not want to lock up and you can feel a slight pulsation in the pedal at a hard stop.
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Have a 14FF under my 91 1/2 ton Sub and have not run into any issues (other than no parking brake, but understand those to be optional equipment anyways???)
    I think the 'sensor' is up-stream (in the trans case/tranny?) and nothing on the axle/backing plate. I've had the axle in there about 18 months now. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  5. BurbinOR
    5,829
    Oregon
    Cool. Meeting him tomorrow morning to try to finalize the deal. It has a Gov Lok in it already, (which will be FINE for what this Burb is for) but eventually I'd like to go 14BFF. Also has 4.10 gears and the 4L80E tranny.............glad to hear lifting it shouldn't affect the ABS.
    Thanks all. /forums/images/graemlins/burb.gif
