'91 crewcab engine bay pics,please
Discussion in 'The Garage' started by johnnychimpo, Jan 21, 2007.
  1. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    I need pics of a '91 crewcab ('73-'87 body style) engine pulley setup. Mine looks like an '86 setup w/the serp/v-blet setup. My '90 sub has a full serpbelt.Anyone know if this is correct for the '91 Crewcab or has it been hacked up? The crewcab has a v-belt driven alt. on the pass side & the air cond. compressor on the driver side, just the opposite of my sub.
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Both my 91 crew cab and a friends 89 (both 350's) had the "V" / multi groove belt set up. My 91 K5 had a serp set up, not sure why some are different unless it's a 1 ton thing. :dunno:
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I don't have pics of the intact engine bay for my '91 crew w/350TBI. :(
    I do know it had a short manually-tensioned serp. belt that looped the alt, water pump, and crank. Then a separate v-belt for the crank, WP, and power steering.
    BTW, no smog pump or air conditioning on mine. ;)
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    My '91 'Burb has the full serp. setup. It's a 3/4 ton.
  5. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Btw, if Bulldogk5 sees this he may be able to help with some pics. :wink1:
  6. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    This helps alot. The alternator spacer on mine looks to be engineered differently than the fsctory did it.
  7. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Nothing but rain here all day. Haven't even driven it around the block other than the drive home yesterday.:wink1: I will try to get some pics tomorrow for ya.
    It pretty much sounds like this though.
  8. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Here is my 90. It should be fairly similar. I know you can't see the belts, but I have the grooved belt and v-belt set up.
  9. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Thanks man, It will be appreciated.
  10. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    My air cond pump and alt. don't look like these. They're on the same sides but the alt. on mine looks like it's been replaced with an older one.Thanks for the pic.
  11. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Iirc, Aramp1's truck has a big block so the a/c comp will be different.
  12. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    PM me your e-mail addy. and I will send them to you.:deal:
