91 heater hose assembly replacement part
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex, Oct 24, 2002.
  1. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    I need to replace the heater hose assembly for my 91. It is the one with the pipe and pressed fitting coming from the intake to the heater. The dealer wants $60. Has anyone found a cheaper one or did you just cut the pipe by the fitting and replaced it with a standard 5/8 hose? I am unable to locate one at my local part stores. /forums/images/graemlins/1zhelp.gif
  2. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    Take the fitting that screws in ti the intake to a parts store and match the size and threads up with the older style chev.barbed intake fitting and be done with it, these pot metal fittings are known to leak, you may have to use an ease out to get this thing out of the intake.
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Is it the one in the back on the passengerside that's metal partly then turns to rubber? If so I just cut the sleeve that held the rubber to the metal and then put a normal hose and clamp on there.
  4. Alex
    Jun 19, 2001
    78
    Northern California
    James, that's the one. Is it working out fine for you? Any leaks? Also does the 5/8 inch hose fit OK on both the pipe and heater nipple side? /forums/images/graemlins/thumb.gif
  5. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    No problems so far. On the size i'm not sure if it's 5/8 since one of the hoses is smaller /forums/images/graemlins/smirk.gif but it is the same size on both ends. /forums/images/graemlins/k5.gif
