91 k5 sitting for 2 years - fuel ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boscolingus, Nov 27, 2001.
  1. Boscolingus
    Boscolingus 1/2 ton status
    Nov 26, 2001
    210
    Santa Clarita, CA
    91 k5 sitting for 2 years - fuel ?\'s
    ok - so a full tank of gas was in the thing the last time it was driven, now that I want to get her back on the road what kind of recommendations are there for purging the fuel system?
    draining the tank, injectors, fuel lines, etc?
    Got my 91 K5 back after 2 years - and man I need parts - BAD!!!!
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Re: 91 k5 sitting for 2 years - fuel ?\'s
    Drain tank, and fill with gas. Disconnect fuel line at tbi with someone in truck have them turn on and off key to run fuel pump. Do this several time while you hold a bucket under line. Than change fuel filter. I would recoment taking apart throttle body and cleaning. Also while tank is down I would change fuel pumps and check tank for internal corrosion.
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> How about for a carburated motor ?
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    L8r,
  5. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    L8r,
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Ooooooooops ! Sorry ...It's late and I'm, loosing it. I still pose the question ....... caburated ?'
    L8r,
  7. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    If the gas is a few years old I'd run it and see if it works. Older gas like in the 80's would laquer up but new gas seems impervious to that, much more stable. I'd dip something in the tank like a hose and if the gas seems clear and normal I'd run it.
  8. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Um, put some HEAT in there. It's Alcohol to strip water out of the gas. If it's been sitting it might have gotten water in the tank.
  9. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I would also recommend pre oiling the motor if it has sat for 2 years. I seen a neat thing, i forget where, using an old distributer with the cam gear removed and the shaft modified to attach to a drill. Spin the oil pump clockwise and build up some oil pressure for a few minutes. Helps to prevent a dry start.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
