91 K5 spedo does not work
Discussion in 'The Garage' started by 84CUCV, Nov 29, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    No idea what is going on with this. When i am doing about 60mph the engine light comes on, then goes out. After that the spedo needle jumps up and down and the e break light stayes on. So what is up with my truck? Could it be a bad cable on the spedo? thx for the help
  2. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    In 91 there is no speedo cable it is a vss located on the tailshaft housing. You also have a rear wheel anti-lock brake module next to the brake master cylinder. The vss sends the signal to the module and after the module it goes to the computer, after the computer it then finally goes to the gauge. Check the brake module connections since the e-brake light in this model is also the RWAL brake light. And if the brake module is shot the speedo will not register correctly if at all.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    What do you mean by RWAL?
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thx
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Where can i get a scaner so i can go see what codes i have? I would think they are all just about the same. right??
    thx mike
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just put a jumper wire or paper clip between a and b on the aldl and the SES light will flash codes starting with the code 12 handshake 3 times and then any stored fault codes.
  8. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    FWIW, my check engine light came on in my 88 when I broke the speedo cable. It was the computer bitching at me because it couldnt lock the torque converter.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thx guys
