91 k5 tbi noob questions
Discussion in 'The Injection Section' started by 84CUCV, Oct 4, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    well, what i am wondering is how do you know if you are getting all your power out of it. Mine sound ok but sometimes it seams that the rpms go up and down a bit. is this normal? Also, what would be some simple bolt ones for more power? as always thx for the help guys.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    what do you mean by the rpm's going up and down? Is the engien surging under a constant throttle postion? There are a lot of mods around that you can do like a cold air intake, throttle body spacer, custom chip etc
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    could be a vacuum leak......bad IAC.....etc. When does this happen?
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    what 1979jimmy said that is what happens. this normal?
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    vaccum leak most likely, check all the vac lines to make sure not are cracked, or collapsed
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    ok i will give it a shot thx
  7. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    when mine would surge and have a weird idle i couldnt find problem. i replaced 02,fuel filter,tuneup,egr and that never solved it..then one day my truck died on me and wouldnt let me go above 5 mph until it cooled off and i wold start it back up again. turned out to be ignition control module(i think) picked one up for around 40 bucks and trucks been running great
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    how do i test the ignition control module? is there a way. What is near Vineland NJ? Never heard of that town.
  9. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    umm close to bridgeton,millville,glassboro(kinda like 30 mins away) basically south jersey
    not sure on how you would test it but what exactly is it doing? when mine was bad my rpms at idle would go down a bit and the truck would sound like it was about to die then pick up..and keep doing it.. i never noticed any misses at higher rpms though
  10. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    chains like Autozone, Kragen's, CHecker, etc. should be able to test the module for you for free. Make sure they test it a few times in a row to warm up the module. Sometimes they only missoperate when they are warm/hot.
  11. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    yep thats when mine would idle weird was once it was warm
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    doing just what you said. If i dont let it warm up and i put it into gear, sometimes it dies. So i let it warm up for a while. When it goes up and down at idle its very little, but it has stop running a few times. thanks for the help
  13. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    FWIW, my TBI 454 has an up and down idle as well- about 35-50 RPMs either way. However, there are no other performance issues. I guess the reason I'm bringing this up is that there may be a chance that your idle issues and stalling issues are not related.
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks I will look into this shortly.
  15. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    If it is the IAC it will fluctuate warm and cold. more then 50 rpm
    ignition module...only when the engine is warmed up.
    Also, may be vac leak,
    I know where vineland NJ is:eek1:
