91 slight surge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex, Jun 13, 2003.
  1. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    Hi all, I get a slight surge (down from idle) when I'm at a stop sign. It does not occur when the truck is cold just when it is warm. Besides that, the truck runs great but I cannot seem to find the problem. The cap/rotor/plugs/wires/injectors are fine. Any idea what may be wrong? Thanks in advance. /forums/images/graemlins/thinking.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would check the EGR valve... /forums/images/graemlins/thinking.gif
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    my 91 sub acted similar (along with a few other issues) and finally threw a TPS code. As i'd changed it less than 2 years earlier i didn't believe it, and finally DID change it.
    That resolved all my issues and runs great now! Even seems to have picked up the mileage a bit! /forums/images/graemlins/shocked.gif
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    First check for trouble codes and repair any problems.
    If there are no trouble codes:
    Check all your vacume lines and Throttle body gasket for leaks.
    Pull off your EGR valve and clean it out with carb cleaner.
    Wouldn't hurt to pull and clean off the IAC valve either.
    As said in above post a faulty TPS can cause surging also.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Not meanin to hijack your post, but, in my 87 i have a surge at idle, sometimes feeling like its gonna cut off. When it gets warm, is when it does it, but it doesnt do it everytime. Same thing with when i get on the gas from a full stop, feels like no power and almost a miss, but it doesnt do it everytime. Could this be a TPS? Everything on the ignition minus the distributor itself was changed in january or early feb. If this could be TPS (i havent had time to check for codes yet) where is it located? Anyone have a pic? Is it hard to change? About how much does it cost? Thanks.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok there are no codes, all the plugs are clean. I broke a plug so when i go to autozone to get one i might go ahead and get a TPS and look for it on the truck as i have no idea where it is or what it looks like. Should i get one for an 87 or an 89 (engine), if they are different pn's?
  7. woody9
    May 27, 2001
    602
    Howell, MI
    TPS plugs into pass side of TBI. A couple small bolts, and a slight range of travel for adjustment on it. It almost reminded me of those old manual choke covers.
    I think they run around $30.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    be sure to check all the sensors, but also check the wires. I had a surge, and my O2 sensor wire had the insulation stripped off, with a wiring harness crossing it, right where it was stripped. the voltages jumped around, sending wierd readings to the computer
  9. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Hey my truck does the exact same thing. Mine gets worse when the a/c is kicked on. I have already done the TPS (I did get a low TPS code before, now it doesnt) and done a full tuneup. I replaced a half dozen bad or suspect vacuum lines. It runs better, but I still have this surge of about 100 rpms. I am getting an EGR code, so that is the next thing coming off for inspection
  10. dyeager535
    26,982
    191
    You may end up having to "adjust" the TPS if you get a new one anyways, might I suggest making sure yours is working correctly before throwing $30 away?
    I'm sure a search on here or google will yield TPS test procedures.
  11. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    My 91 does the same thing. I'm pulling 21 vaccum, replaced ignition with MSD coil, 6a box, super conductor wires. Checked the TPS with multi-meter according to manual. No codes. I guess the EGR is the next thing to check. Thanks guys.
  12. woody9
    May 27, 2001
    602
    Howell, MI
    oops, almost forgot. One other thing on that was to clear the computer (batt disconnected for a few minutes), once the new one is in place, KEY ON (NOT STARTED), and give the accel a FULL cycle - idle to WFO and hold briefly, then key back off. Supposedly allows computer to LEARN the full TPS range.
    Not sure if it was the new sensor that did it, or the re-programing??? Either way, much better now!
