91 with no O2 sensor?
Discussion in 'The Garage' started by MR4WD, Jun 22, 2003.
  1. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    A recent thread inspired this. I've got a 91 blazer, 350 with no accesories. The accessory belt only powers the water pump, power steering and alternator. There's no A.I.R. pump, or A/C. Should there be an A.I.R. pump? Furthermore, just before I bought the truck it had the exhaust replaced and the new exhaust came without an o2 sensor. Is there supposed to be one? Where in the harness does the o2 wiring feed back to if there is one?
    That would explain the poor fuel economy and rough idling issues I've been having, but I'm stumped as to why there isn't any check engine light glowing?
    Thanks for your help, Chad.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'm not sure what the reasons were but some earlier TBI trucks got the AIR and some didn't. My 88 1/2 ton with 350 and 5 speed did, but I have seen quite a few that didn't get any AIR pumps at all.
    It should have an O2 sensor though...
    Rene
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I dont have the ECM pinouts on hand right now, but the 02 is a single purple wire.
  4. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    does the check engine light come on when you turn key on??
    reason i ask prevouse owner may have unhooked it.
    dave
  5. dyeager535
    26,979
    I'd suspect the SES bulb has been removed or is dead.
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I think A.I.R. pumps were only on California models. I'm not sure about Canadian models.
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    only trucks that came with california emissions will have the A.I.R. pump. mine came from missouri, and it had spent it's whole life there from brand new until i got it in 2000 and then i got transferred to las vegas 2 months after i bought it. and it's got that damn A.I.R. pump on it. as for the O2 sensor, i believe they should all have one.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You must have a 02 sensor for the fuel injection to operate properly. The ECM needs the feed back from the 02 so it can regulate the air to fuel mixture. Without the 02 the ECM goes into bypass mode, ignores most of the sensor input and runs on a pre programed set of operating values. This usually results in the problems you are having.
    You dont need the AIR system. But you do need to have all the sensors hooked up and operating for a FI system to work right.
    The 02 is usually located on the drivers side just below the exhaust manifold. Look around that area there should be a single wire connector hanging out.(unless someone clipped it off)
    As for the CE light if it does not come on when the key is turned on. The bulb is bad or has been removed.
  9. MR4WD
    Jul 28, 2002
    133
    The check engine light comes on until I start the vehicle. The light is fully operational. It does not function while the engine is running however. Thanks for the input, I find it novel that there is no o2 sensor and the truck still runs, albeit rough. I know vehicles pretty good, but I haven't torn into this blazer much. I rebuilt the winch, replaced the thermostat, knock sensor and coolant sensor. The last two were in hopes of fixing the erratic idle, and constant advance. It runs quite rich as well. I'll look around for purple wires that have been clipped and also look into welding in a bung for an o2 sensor.
    Again, thanks. I'll let you know how I make out.
  10. MR4WD
    Jul 28, 2002
    133
    Furthermore, I've also done the "put the paper clip in the diagnostic port and count the flashes trick", but that comes up with nothing. Just the self diagnostic code 42 or whatever the heck it was.
