92 and newer Blazers with Manual Trannys?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Sep 19, 2001.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Does anyone know if the newer 92 K1500 Blazers came with manual trannys?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Some did, but they're comparitively rare - mostly in the stripper models.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Do you know if any had the Z71 package on them? Thanks.
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've seen a couple Silverado/Z71's with a 5 speed.
  5. buzzk5
    buzzk5 Registered Member
    Aug 30, 2001
    29
    gimli,mb,ca
    hey pugs
    do you know if i can swap a newer 5 spd manual/odrve trans into a 77K5 ???
    its still auto and im lookin for a std set up...pedals in got clutch and bell
    will it bolt up/work with my case/bell or am i lookin for a complete driveline ???
    any body done thisssss ?????.....
    Dave
    80K5 on ice
    are they all spinning?????
  6. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I put the NV4500 5 speed in without much problem. Advance Adapters sells the bellhousing and hardware you'll need if you have to adapt to 205 transfer case, otherwise 208 or 241 just bolt up to trans.
    87 K5, D60, 14FF, NV4500 & NP208
    Build it Bulletproof and take it fishing!
  7. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    If you are go with the NV4500 use the GM part for it much cheaper the Advanced Adapter and much nicer parts
  8. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    The 5 speed overdrive manuals found in the 88 and newer 1/2 tons are not NV 4500's, they are more or less a car tranny made by getrag. They do not have a separate bell housing and do not have a granny low first gear. Just a heads up in case you're looking for one.
    Rene
