92 Auto to manual swap
Discussion in 'The Garage' started by b454rat, May 3, 2007.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Found a good deal on a 92 Blazer, bad 700 trans. (go figure) Curious what is involved swapping them out. I have the pedals, the column, trans/case, but what about the ECM?? Do I need to swap the chip for the standard one?? I'm tired of autos.....
  2. udy2554
    udy2554 1/2 ton status Premium Member
    Mar 31, 2007
    1,172
    5
    Naples, N.Y.
    a few years back, I swapped in a 465/205 combo into an 88 blazer. Didn't have to do anything with the computer, tho i did use the Jet 6-pack. all seemed to work fine.
  3. dyeager535
    26,979
    You'd be happier with a manual chip. Throttle following, holding RPM higher when you are shifting, etc.
  4. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    That's what I figured. Buddy has a few of these in his yard, so maybe I'll rob some parts from some. Talked to the guy about the Blazer, wants $600 for it. Almost 200k, little rusty around the edges, pass seat reclined, stuck in that position. Has a visor, stupid scoop on the hood, 'glass DeeZee running boards, (might actually keep them after I replace the rockers) Z-71 and I think Sport package, at least the Z-71. Didnt look at it for long, nobody home and didn't want to get shot (not the best neighborhood) but gonna go look at it tomorrow, owner said it was cool. After I take a closer look, then I'll know if it's something that I want to mess with....
  5. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Trying to figure out all the parts that I need to swap. I have the pedals and column. Only thing that I can think of is the bell, trans, t-case, x-member, maybe driveshaft. Oh and the chip from the ECM. Sound right? Flywheel and clutch too!!!
