'92 GMC K2500 hubs wont engage...
Discussion in 'The Garage' started by bud991649, Jun 7, 2005.
  1. bud991649
    bud991649 Registered Member
    Dec 28, 2004
    7
    South Florida
    Transfer case is fine, driveshaft and axles spin, but no tire spin. Any ideas as to why the front hubs would just stop working and what to do to fix them?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Actuator is bad, probably. For more positive engagement, look at the Posi-lok. They're $180 on 4wheelparts.com. It replaces the actuator motor that thermal or vacuum operated with a cable you pull when you want 4x4.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you want to keep it automatic, the GM dealer sells an updated actuator that is more reliable. You also need a wiring adapter to make it work with your present setup. :cool1:
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I have posi lock, works great. kinda brings the manual aspect back into the picture, but it does give you the advantage of a low range 2wd for backing up trailers and what not at ultra low speeds.
  5. bud991649
    Dec 28, 2004
    7
    South Florida
    I will compare the prices of the OEM and the Posi-Lok and probably go with the posi-lok, it is alot better anyway, 2 wheel low is a wonderful thing... Unfortunantly I have it now under hte wrong circumstaces...
