92 s-10 rear springs with 12 inches of lift
Discussion in 'The Garage' started by promudder, Oct 31, 2002.
  1. promudder
    promudder 1/2 ton status
    Nov 14, 2001
    117
    does anyone know where i can get some rear springs for a 92 s-10 with 8-12 inches of lift? i am doing a solid axle in the front and keeping the stock frame.any help would be great!
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    wow, I hope you are using full size width axles, thats a lot of lift. Probably have to get them custom made by a shop. Crap, can't think of a name, but I know the 4WD magazines get springs made for their applications a lot. /forums/images/graemlins/crazy.gif
  3. promudder
    Nov 14, 2001
    117
    i am putting a d44 in front and a 12 bolt in rear. with a divorced transfercase because this truck is a 2wd. the shops around here dont want to help me.
  4. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    National spring or Alcan spring, both will build you the springs you want. Won't be cheap though /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You should start off with a axle flip (from spring under to spring over). You should end up with around 5" of lift from that alown. Then you can make some longer shackles and put some short blocks in and you might not have to even put in add-a-leaves.
