'92 Suburban Blinker Issue ......
Discussion in '1992-Present Chevy & GMC models' started by Stoopalini, Dec 12, 2002.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    \'92 Suburban Blinker Issue ......
    A buddy of mine has a '92 Suburban, and for some reason, the front right blinker will not work. The rear right works fine, and the 4-way flashers work on all 4 corners, but the front right doesn't flash at all.
    We tried swapping the front left and right bulbs, but had the same results.
    Is there something in the column that would cause just the front right blinker not to flash but keep the rear right one working?
    Any help is appreciated,
    Thomas.
  2. Yukoneer
    Yukoneer Registered Member
    Sep 23, 2002
    10
    Rochester Institute of Technology
    Re: \'92 Suburban Blinker Issue ......
    check the blinker lines... i had a prob w/my taillamps once and the prob turned out was a burned out wire..
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks for the reply. I'm pretty sure he fixed it with a new turn signal relay. Kinda wierd that a bad relay would cause just one signal not to work?
    Thomas.
