92 Yukon Dead Any Ideas
Discussion in '1992-Present Chevy & GMC models' started by STV, Jul 2, 2002.
  1. STV
    STV Registered Member
    Dec 16, 2000
    25
    Winnipeg, MB Canada
    Thought it was a fuel problem. Replaced fuel pump and relay. Found out I have no power at injections with key on and I have no spark. Changed ignition module and still nothing? Any ideas as this parts trial and error is getting expensive. Thanks.
    Brad
    92 Yukon, 6-1/2" Lift, 35's. /forums/images/icons/frown.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that you're getting 12 volts to the distributor. The injectors get their signal to fire from the ignition module. So if that signal isn't generated, then the injectors won't spray any fuel. /forums/images/icons/frown.gif
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    did you check the coil? What about the pick up coil in the distributor? Not too hard to replace either...are you getting a spark?
