93 6.2 problems
Discussion in 'The Garage' started by dogdaysunrise, Mar 26, 2006.
  1. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    My GF's dad is having problems with his 93 6.2l. At WOT the EGR is not closing. It as well as the epr are getting power at idle. When the power is manually removed from the EGR solenoid the EGR is still not closing. This is causing some major smoking, and poor millage.
    I was thinking that it was the TPS, but then the fact that when the power is removed from the EGR solenoid the EGR still doesnt close kind of throws a wrench into the TPS idea.
    I was searching around on here and found how to calibrate a TPS on a gas motor, and was just wondering if it was the same on a 6.2.
    Thanks in advance
  2. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    hmmmm....
    I'm not very well versed on diesel EGR valves,but I thought on a 6.2 I read they are supposed to be open at idle,and close during acceleration..they work in conjunction with the EPR valve located in one exhaust manifold(same thing as a heat riser on a gas motor)...
    My 6.2's EGR is disconnected,and it smokes pretty good upon acceleration..but it doesn't run bad or get poor mileage,at least I thought 16-22 mpg wasn't bad for a 3/4 ton 4x4..:dunno: ..ones that have a "J" code enjine and intake have NO EGR valve whatsoever!..:crazy:
    By "TPS",if you mean "throttle position sensor",my 6.2 has no such thing,its mechanical fuel injection..a 93 might though if its computerized..you'll need to speak with someone with more knowledge of newer trucks than me on that one!..:eek1:
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    EGR's are kinda useless anyways. Im surprised you have a 93 with a non turbo. 92 was the transition year.
    However, even if the EGR was open I doubt it should be producting black smoke. (maybe lack of power, but not smoke). Black smoke means unburnt fuel.
    I forget how you plug up the EGR, you dont need it.
    Black smoke however, means that you might have something wrong with the fuel- how many miles? It could be the injectors dribbling
  4. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    well from what I have read, the TPS cuts power to the solenoids at 15degrees throttle position. and also controls the shift points of the 700r.
  5. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    well the black smoke isnt so much of a concern. It is more of the loss of power and poor millage that is concerning him.
  6. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
