93' 'burb DD electrical problem: HELP!
Discussion in 'Other Rides' started by mtn. burb, Jul 19, 2004.
  1. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    93\' \'burb DD electrical problem: HELP!
    The DD's speedo and tachometer bounce all over the dial when driving. This happens part of the time, but almost always when you use the power windows. The alternator is charging. The battery is fine, replaced a few months ago.
    Is it a ground problem? /forums/images/graemlins/1zhelp.gif
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Re: 93\' \'burb DD electrical problem: HELP!
    Yep sounds like a bad ground to me. Might have to pull the dash and check all the connections
