93 s15 Jimmy 4wd not working
Discussion in 'The Garage' started by nomind, Nov 21, 2005.
  1. nomind
    nomind Newbie
    Nov 21, 2005
    3
    North Dakota
    Anybody no why 4wd doesn't work. It is push button. It doesn't do anyting unless it is revearse, and even then, it doesn't always go into 4wd. I have replaced transfer case switch, and checked the lines. Sometimes when I start it, you can hear a noise behind the switch.
  2. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    does the tcase not go into gear or the frt axle doesnt go into gear ?
    if the frt axle doesnt go into gear, check the vacume lines
  3. nomind
    nomind Newbie
    Nov 21, 2005
    3
    North Dakota
    Thanks for the info. Last
    night, I found hole in the line. Spliced it, and it worked after I started it. Started it an hour later, and it doesn't work???????????? It is doing the same same thing. I am going to check for another leak. If any other iedeas, let me know. Thanks again!!!
