Discussion in 'The Garage' started by nicotine, Jan 13, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    ok i did a search on this and i have asked before over at offroad.com but i still cant find 8 to 6 lug adapters/spacers i know i have seen them before and requires you to machine the axle down so it will fit in a 15inch wheel. if anyone knows were i can get this it would help alot. /forums/images/graemlins/confused.gif thanx
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    They used to be sold on echobit, but I think it was Waxer making them. PM him on here. If he wasn't the one, he'll likely know who was.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    TonyP makes them. /forums/images/graemlins/thumb.gif
  5. Skigirl
    Apr 2, 2001
    2,563
    Oops. Right - TonyP... /forums/images/graemlins/pimp1.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so 6 of the opriginal 8 studs holds the adapters on ?
    hmm... interesting.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
  8. nicotine
    Jan 11, 2004
    116
    how can i get ahold of tony p?
    /forums/images/graemlins/usaflag.gif
  9. nicotine
    Jan 11, 2004
    116
    (so 6 of the opriginal 8 studs holds the adapters on ?)
    i am pretty sure there should be 8 studs holding the adapter on and 6 going to the wheel.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The overlay of the bolt patterns does not allow for use of 2 of the 8 studs. The missing studs are 180° from each other. That is the only way I have seen it done. There really isn't a strength issue. An 8 lug uses 9/16 studs and a lot of 6 lug use 7/16 studs (WTF?)
  11. nicotine
    Jan 11, 2004
    116
    then what happens to those two studs that overlay? they stay dont they?
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It appears that your'e going to have to knock those out of the hub.
  13. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    there are tons of companys that make these look on
    www.sema.org and find exhibitor listings under wheel adapters there were about 6 different companys at the sema show in vegas that are building these they are made out of 6061 alluminum and are strong ass hell.
  14. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
  15. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    very well said /forums/images/graemlins/thumb.gif
    the wheel is held on with 6 7/16"inch studs and the spacer is held on with 6 9/16:inch studs...
    I make them from 6061 T6 alum.
  16. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Hey Tony, are these still strong? any danger for a daily driver?
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    not at all, alot of guys are running 1" to 2" inch spacers on there axles, and the six 9/16"inch wheel studs that hold the spacer ring on are alot stronger then the six 7/16"inch wheel studs that hold the rim on...
