94 454 ¾ sub Surging at night only !! update !!
Discussion in '1936-Present Suburban' started by WakeBoard&4X4er, Aug 15, 2003.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Last night I was driving my 94 sub home with a trailer for the first time, when I noticed some things. At 70 mph the truck would surge some? I looked that the temp and it was ok, but the volts were down in the 11.5-12.5 range, is that normal? I have been noticed that when I drive with the AC in the day the same problem. I was thinking I would find out what the deal is before I take off with my blazer on the trailer.
    This is what I am thinking,
    1. alternator is going bad.
    2. new Fuel Filter.
    3. know it needs a new belt.
    4. Friend thinks it my be the battery.
    What I think I might do is pull the battery from the blazer and put it in the sub and change the belt. It that does not fix, new fuel filter. Last new alternator. If that does not do it I will take to a shop.
    What do you all think???
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Re: 94 454 ¾ sub Surging at night only
    If you haven't changed the fuel filter in a while, I'd do that anyway. Same with the belt. As far as the alt & battery, just take it to a local Checker/Auto Zone and have em both checked. That's easier, cheaper, and will give you a difinative answer on if they are good or not. After that, reevaluate & get an answer from someone much less mechanically challenged than myself /forums/images/graemlins/grin.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like your alternator is near death. Anytime that you have a high current load on it (running at night with lights, or in the daytime with the a/c blower(s) on high) your voltage is dropping. The alternator should be able to maintain 13.8 volts while every gadget on the truck is going full blast. The battery is simply a voltage storage device, it's the alternator that "fills it up". When you're seeing the 11.5 volt readings, the battery is being discharged because the alternator isn't doing it's part. /forums/images/graemlins/frown.gif
    Our '94 Sub maintains 13.8 volts with the a/c on, both the front and rear fans going full blast, the headlights on, wipers running, and the radio playing. /forums/images/graemlins/cool.gif
  4. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Thanks all! i will take it in this week.
  5. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    I'd agree with Harry. Sounds like the alternator is headed South. Mine did that last year-- a couple of goofy days, then BAM, it went to 12V. I was only a couple of miles from home, so I turned around and swapped with the Jeep for the day...
    The good news is that a rebuilt alternator only cost me $43 at an auto electric shop. /forums/images/graemlins/cool.gif
  6. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    another culprit that doesn't get enough love, is the main power split off junction block on the firewall. I dunno if the newer burbs have one or not, but in the case of my older 77, one of the nuts that holds the main power cable on the breakout block was lose, and as such, making minimal contact, and not allowing a proper ammount of power to get from the alternator to anything important like the batteries, the power regulator, the ignition system, or for that matter, anything else on the truck.
    good luck with it,
    -The Ddragggon
  7. Grim-Reaper
    7,385
    Atlanta
    Yep...Alternator. Mine crapped out a couple weeks ago and was doing the same thing. It's probably making enough voltage...the rectifyer is taking a crap and it's going A/C. DC gages reading A/C voltage will read low. DC motors will run slow. Plays hell with the computer. My truck started poping fuses and the CB got radio noise in it when it happend.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the newer trucks have a massive one. It has 4 or 5 posts (very nice for doing "upgrades" on older trucks). /forums/images/graemlins/cool.gif It's hiding under the black plastic cover on the firewall that also houses the fuel pump relay. /forums/images/graemlins/thumb.gif
  9. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    Hey Rich
    This sounds pretty interesting as it's something I've overlooked in squaring my electical system up. I wonder if you have a pic of this guy (main power split off junction block)? I dont have a shop manual yet - just working with Chilton & Haynes for the moment and they dont seem to list this. I suppose I could go out to the /forums/images/graemlins/burb.gif and start tracing wires from the battery & alternator, but it would be easier if I knew what I was looking for /forums/images/graemlins/wink.gif.
    Ben
  10. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    When to Auto Zone and they put my Sub on some computer and it told me that when i was at 2000 i was putting out 13.5 Volts, but at idle i was at 11.2. what do you all make of this?
    Big Block with o/d 3.73 and 30ish tires, i would think at 65 i would not be in the 2000 rpm range, but...
    what should i look at now?
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Did they put a load on it? They need to load the system down, so that the alternator has to work hard to keep up with the demands. And it still should have been able to keep the voltage very close to 13.8 volts at idle.
  12. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    is that so. i do not trust the people at part stores that much, the best store i have heard was of backyard asking about spring bushing at telling them that they are waring out fast, and told him it was because he had a bodylift.
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rotfl.gif
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    OK, I just came back in from the driveway... I fired up the Sub, turned on the headlights, the radio, front a/c on high, rear a/c on high, and even left the door open so all of the interior lights were also on. With the engine idling, my digital voltmeter showed 13.97 volts at the battery. /forums/images/graemlins/cool.gif So it sounds like it's time for you to get an alternator that works properly. /forums/images/graemlins/wink.gif
  14. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    thanks dog!
    you the man!
  15. Ddragggon
    Apr 25, 2001
    2,657
    if it was only putting out 11 at idle on his computer, he should have known your alternator was screwed. hopefully the newer suburban's alternator is up in an easy to access location, like my old skool sub's.
    -Ddragggon
  16. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    yes it was Easy, up top, remove the S belt, 3 bolts 1 pug one nut. i would have taken about 15 mins if the parts store would have gave me the right belt! they one they gave me was about 1 inch to short! /forums/images/graemlins/angryfire.gif
    so i had to drive back there and get the right part. /forums/images/graemlins/rolleyes.gif
    runs better, i think i am going to change the fuel filter asap, but runs about 70% better.
