94 454
Discussion in 'The Garage' started by Afireinside, Feb 1, 2005.
  1. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    I left my manual at work so what is a code 36.I got the normal 12 then 36 the 12 so whats that mean. thanks
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The '94 GM Service manual says that an error 36 is an idle speed control actuator fault.
  3. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It also appears to be unique to the 454. :( Looks like it's a solenoid that controls vacuum to an actuator that helps control idle speed. :confused:
  4. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Thanks does it show where it's located.
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It shows the solenoid near the front of the intake, on the pass. side. The actuator looks like its beside the throttle body, on the drivers side. If I'm looking at it right, there should be a vacuum line running from the solenoid over to the actuator. :cool1:
