'94 Blazer getting a little warm....help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jul 15, 2003.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    \'94 Blazer getting a little warm....help?
    I just bought this Blazer and while I was out and about last night, I noticed that the temp would get up around 240-250 degrees. That's when I was sitting at a light or sitting in park. It's night and day, not always occuring. I had the AC on too. Another thing, it didn't always get warm at a full stop in gear. I think it might be the clutch fan or low fluid level. I haven't had the chance to check the anti-freeze, but anyone who might have suggestions would help. It's not the end of the world, I just want to make sure I get it fixed. One more thing, occasionally I can smell warm coolant inside. There isn't any steam coming out of the engine either. I don't know?! haha
  2. dyeager535
    26,982
    191
    Re: \'94 Blazer getting a little warm....help?
    Sounds like a leaky heater core, and thats maybe why you are running hot...coolant has leaked out somewhere, and the system is low/not building as much pressure as it should.
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Check your radiator cap to make sure its the right poundage and not worn.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    turn the defrost on warm and see if the windshield fogs up on the passenger side and gets slick...probably a heater core..
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    for added cooling, and clearance enhancement, pull the inner fenders. /forums/images/graemlins/thumb.gif
