'94 blazer serpentine belt removal
Discussion in 'The Garage' started by drusky2k5, Jun 15, 2005.
  1. drusky2k5
    drusky2k5 Registered Member
    Apr 21, 2005
    16
    Texas
    I need to replace the alternator on the truck and need to know how to remove the belt to relieve pressure. Which is the tension pulley and how do you loosen it? Also, looking for a good deal on a higher amp alternator for the truck, anyone know of a good parts place that sells them inexpensively? Or the best brand/type to get?
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i dont know about what kind of alt to get but i do know there is just a little levar with a nut on it that holds all the tension to the line. just bend it counter clockwise and slip the belt off.
    MAKE SURE YOU HAVE A DIAGRAM OF HOW IT IS RUN!!!
  3. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    LOOK AT THE AC COMPRESSOR. NOW LOOK JUST RIGHT OF IT YOU WILL SEE A PULLEY WITH AN ARM ON IT. TAKE A WRENCH AND PUT IT ON THE BOLT IN THE CENTER OF THE PULLEY AND PULL UP AND TOWARDS THE PASSANGER SIDE. THIS WILL RELEIVE TENSION ON THE BELT.
    THIS IS MY ENGINE, THE TENSIONER CAN BE SEEN JUST UNDER THE UPPER HOSE TO THE LEFT OF THE ALTERNATOR. IT IS A 95 MODEL IN MY 87 BLAZER.
    HOPE THAT HELPS.
    PS. THERE SHOULD BE A BELT ROUTING DIAGRAM ON YOUR FANSHROUD. IF NOT MAKE SURE YOU LOOK AT THE BELT BEFORE YOU REMOVE IT.
    GABE
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    What he said.....
    But when you remove the belt, and release tension on teh tensioner, do so slowly....if you just let go you will probably break the tensioner and get injured.
    I would also make SURE you are using the right socket size, and i would reccomend doing it only with a 6pt socket. I used a 16 or 18" breaker bar with a 6pt socket and had no trouble.
    If i hadn't already sent my tools home, i'd give you teh socket size....i think its 15 or 16 mm.
    Good luck!
  5. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    just my opinion on this but, I use a long box end wrench. this way the force applied is not at any angle and there is less chance of it cocking sideways and slipping off.
    gabe
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Second that - use a wrench. That thing has some pretty good tension and if it slips its bad.
  7. dhcomp
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    Hm, i never thought of that. Does it stick out far enough to get a wrench on?
  8. drusky2k5
    Apr 21, 2005
    16
    Texas
    Got it
    Thanks guys! I got it off no prob.
