'95 s-10 pick-up missing in 2-5th gear.
Discussion in '1983-2005 S-Series models' started by Blaze69, Dec 5, 2002.
  1. Blaze69
    Blaze69 Registered Member
    Nov 8, 2002
    6
    \'95 s-10 pick-up missing in 2-5th gear.
    Hey all,
    My 95 is missing in the higher gears, not much but just enough where I can feel it. I guess it's not really a miss but hesitate would be a much better word. I tried setting the timing and when I unplugged the connector to bypass the Dist, the truck started changing idle speed. It would go from about 700 to 900. I makes the setup alot harder to do. Anyone have any thoughts on what to check?
    The fuel filter has been changed.
    The injectors flushed and cleaned?
    The spark plugs look good.
    The dist cap and rotor were changed.
    And the clutch recently replaced.
    Thanks,
  2. steve89s10
    steve89s10 Newbie
    Feb 9, 2003
    Re: \'95 s-10 pick-up missing in 2-5th gear.
    The TPS *throttle positioning sensor* might be to blame...
