95 SUB IFS Actuator?
Discussion in '1992-Present Chevy & GMC models' started by dlaw36, Jul 12, 2005.
  1. dlaw36
    dlaw36 Registered Member
    Jan 11, 2003
    71
    I have a 95 IFS and while engaging the 4x4 it grinds and never goes into 4x4. I can kill the motor and engage it, but I am really not sure if it engages the front wheels, and it will grind trying to dis-engage the 4x4 until I kill the motor once again. Is this the actuator or possibly an t-case motor going out? :confused:
  2. dlaw36
    Jan 11, 2003
    71
    Anyone? :confused:
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  4. dlaw36
    Jan 11, 2003
    71
    No it is a manual floor shifter.
  5. divorced
    Jul 20, 2004
    5,115
    Does it grind anywhere or only when you are stuck or in mud?
    My girlfriend's will grind occasionaly when I am stuck and push the button for 4x4. I put the transmission in "reverse" and spin the rear tires just a bit and it locks in.
    Maybe try to take out the front driveshaft and see if it still does it. If the noise is gone I would guess the problem is a front acuator, If you still have noise it could be a problem with the t-case (maybe just a linkage adjustment?)
    Does it grind when you try to move or when you are selecting 4x4 but sitting still?
  6. dlaw36
    Jan 11, 2003
    71
    It will grind sitting still and trying to engage it in 4WD.
    I guess I will take the drive shaft out and and see what happens.
  7. divorced
    Jul 20, 2004
    5,115
    I would guess it has something to do with the t-case. I'm not sure taking the driveshaft out will help.
  8. dlaw36
    Jan 11, 2003
    71
    :( I am thinking that it is the t-case too.
    Thanks for the help!
  9. divorced
    Jul 20, 2004
    5,115
    It may just need an adjustment, or maybe a shift fork is bent. I don't know too much about the internals of a t-case :crazy:
