'95-up gear-red. starter?
Discussion in 'The Garage' started by roadnotca, Apr 3, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Anybody tried this upgrade, '95 and up permanent magnet, gear reduction starter. I know it also needs a relay. I was just wonderin if anybody has tried it and is it really cool and is the starter probably twice the price?
    This would be kinda like the alternator upgrade, SI to CS.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    personally they are barely smaller or stronger than a standard old style starter, buying a smaller aftermarket gear reduction for about the same price would be a better.
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I put one on mine. Bolted right up. Why do you need to add a relay ?
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    This was my experience also. ;)
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I've read that with a ford solenoid set-up, without relay, the permanent magnet allows the starter to become a generator, it will continue to run after the engine has started.
    Otherwise, the only reason to use one of these is if you have tall compression ratio?? The gear reduction is no help with low battery(ies)?
    Thanks:D
  6. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    The 95 starters are a direct bolt in. I did this to mine. I also feel they are quite a bit less noisy not that it really matters to me or most people. And yes there are at least double the price. But I got mine for free so I can't complain.
  7. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Permanent magnet starters also require less current to start your engine. The older style you were energizing both the stator and rotor. Permanent magnet types you just energize the stator.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    In retrospect, I should have started this as a poll; but it sounds like with a good guy price, or free, its a cool upgrade(?). Otherwise unless we're talking 11:1 monster motor, $200 for a starter is bling.
    Thanks guys.
