'95 Yukon "Electronic Spark Timing" Bypass
Discussion in '1992-Present Chevy & GMC models' started by BigBen, Dec 7, 2003.
  1. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    \'95 Yukon \"Electronic Spark Timing\" Bypass
    Today I was trying to check the base ignition timing on my '95 Yukon with 5.7 L TBI (non-vortec) engine.
    I need to bypass the Electronic Spark Timing (EST) according to the emissions decal on the truck and the Haynes manual. My Haynes only indicates a plug behind a relay cover on the upper passenger side firewall. My Yukon doesn't have the relay cover indicated (or the plug), but has a fuse/relay center on the driver's side below the master cylinder.
    Needless to say, I scanned around the relay center and the wiring harness looking for a plug with a tan/black stripe wire coming into it. No Luck.
    Does anyone know how to, or have a manual that says how to disconnect the EST on a '95?????
    Thanks,
    -Ben
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Re: \'95 Yukon \"Electronic Spark Timing\" Bypass
    Should be inside the cab, in a bundle down by the blower motor under the dash.
  3. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Should be a tan wire with black tracer.
