'95 Yukon Front Suspension Squeak?
Discussion in '1992-Present Chevy & GMC models' started by BigBen, Sep 1, 2006.
  1. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Ok all,
    1995 Yukon GT with 216,500 miles on her.
    Up in Alaska in '04 (145,000 miles) I thought I was hearing a "clang" in my front supspension when I hit bumps, but now I think it is a squeak.
    I've checked everything several times for tightness, and had a shop check things too. My girlfriend claims she can hear it from her car when she is driving behind me.
    It happens when I hit bumps. It seems to squeak on both the up and down strokes. I'm thinking it may be the IFS bushings squeaking... but not sure.
    Has anyone heard this on their IFS rig?
    Solved it?
    Is there something I can do to 'lube' the bushing that won't harm things?
    I love my truck, but the squeak is getting annoying!
    Thanks,
    -Ben
  2. bggrnchvy
    bggrnchvy Registered Member
    Jan 21, 2005
    48
    Cupertino, CA
    I had the same problem and it was shock eye's in the shock towers. I got some cheap metal tubing at the hardware store and cut inserts to keep the eye located in the middle of the tower and the squeaking went away.
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Have you tried jouncing the truck while it is sitting still to make the noise? We usually have one person jounce while another moves around and touches everything till we find the noise. If something is squeaking, you can usually feel a vibration in it too.
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Check the control arm bushings.. Fairly common problem
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    silicone spray to lube the bushings temporarily should work.
    if not, cut it all out and add a Dana 44. :deal:
  6. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The sway bar bushings wear quickly and could also make the noise you describe after they disentegrate and the washers start rattling around. That's happened to most of the IFS trucks that I've seen.
