96-99 2 door tahoe gas tank size.
Discussion in '1992-Present Chevy & GMC models' started by 87GMCJimmy, Apr 3, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I'm putting a 5.7 vortec into my 87 Jimmy and was wondering if a gas tank with the in tank fuel pump from a 2 door 96-99 tahoe would fit into the 87. How much different are these frames back there? Does anyone have one of these trucks to take a quick look/messurements. Any help is greatly appreciated.
    Mike
  2. 70_K5
    70_K5 Registered Member
    Feb 16, 2001
    25
    my 99 tahoe is around 30" side to side, 22" front to back and about 14" high i hope that helps
  3. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Thanks!! I'll have to look into this.
    Mike
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    If you do go with a fuel pump from a Tahoe....do not use the 4 door model. I just replaced the fuel pump in my 4 door, it cost me $300.00 A 2 door pump was only $89.00.
    P.S. I have a 4 door fuel pump if you wnt to try and rebuild it.
  5. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Wow, I wonder what the difference is. Maybe I could just get the 2 door pump and install it into my 87 tank somehow.
    Mike
  6. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Just went to Autozone at lunch and I OWE YOU BIG TIME!!! The 2 door blazer has the high pressure pump that looks exactly like the TBI pump and should fix perfectly. I can just use my old tank and everything. This design must have been a hold over or something from the previous TBI system for some reason. All the other truck/subs/tahoe's use a combination sender/pump thingy that's 2-3 hundred bucks and the 2 door tahoe fuel pump is just 71.99! This kicks some major booty.....
    Thanks!
    Mike
  7. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    You can send me $300.00 if it will make you fell better.........Just kidding, glad I could help.
